Transparent Crystal 10mm 3-Pin LED Strip Connector Demo – Solderless Installation
- Transparent crystal LED strip connectors for a clean, low-profile look
- Compatible with 10 mm width LED strips in a 3-pin configuration
- Solderless clip design for quick and easy installation
- Supports both strip-to-strip and strip-to-wire connections
- Clear housing helps keep connections visually discreet
- Local stock available in the US and UK
- LED strip lighting installations
- Projects requiring clean and hidden connections
- Indoor LED strip setups where appearance matters
| Connector Type | LED strip connector |
| Width Compatibility | 10 mm |
| Pin Configuration | 3-pin |
| Installation Method | Solderless clip |
| Connection Types | Strip-to-strip, strip-to-wire |
Q: Does this connector require soldering?
A: No, it uses a solderless clip design.
Q: What LED strip width is supported?
A: It is designed for 10 mm wide LED strips.
Q: What type of connection does it support?
A: It supports both strip-to-strip and strip-to-wire connections.
Q: Is the connector visible after installation?
A: The transparent crystal housing helps keep the connection visually discreet.
