S1616 16×16mm Silicone Neon Light Housing – IP67 Waterproof LED Channel Demo
Discover the S1616 silicone neon light housing designed for 16×16 mm LED channel applications. With IP67 waterproof protection and support for 12 mm LED PCBs, it delivers smooth, uniform neon-style lighting. Ideal for large-format architectural accents, signage outlines, and outdoor decorative projects.
Key Highlights in This Video
  • 16 × 16 mm silicone neon light housing for high-diffusion LED lighting
  • Designed for 12 mm LED PCB width
  • IP67 waterproof level suitable for both indoor and outdoor installations
  • Strong, flexible silicone material allows shaping along curves and outlines
  • Comes in a 16.4 ft (5 m) roll for extended lighting projects
  • Provides bright, uniform neon-style illumination without hotspots
  • Model: S1616 Neon Light Housing
  • Dimensions: 16 × 16 mm
  • Compatible PCB Width: 12 mm
  • Material: Flexible silicone
  • Waterproof Rating: IP67
  • Length: 16.4 ft (5 m) per roll
  • Use Cases: Architectural contour lighting, signage outlines, outdoor decorative lighting
Frequently Asked Questions
Q: Is the S1616 housing suitable for outdoor lighting?
A: Yes, its IP67 waterproof rating ensures excellent resistance to moisture and dust.
Q: What LED strip size fits this housing?
A: It is compatible with LED strips using a 12 mm PCB.
Q: Can the silicone housing be bent?
A: Yes, the flexible silicone allows curved and shaped installations.
Q: What are common applications?
A: It is ideal for signage borders, architectural accent lines, and decorative outdoor lighting.
Led neon light housing
