[Complete Guide] Differences and Applications of Red and Infrared LED Strips from 635 nm to 940 nm
In the field of professional lighting and optoelectronics, red and infrared LED strips play unique roles across research, agriculture, healthcare, industry, and security. When shopping, you may notice that these “red” strips actually come in different wavelengths and serve very different purposes. Understanding each wavelength’s characteristics and differences is the key to choosing the right product.
What Are the Uses of Each Wavelength from Red to Infrared?
The difference between red and infrared lies primarily in wavelength and visibility.
635 nm is within the visible red light range, emitting bright, clear light that’s often used for visual indicators, signage, décor, and observation in experiments.
660 nm is deeper red, still visible but closer to the far-red range. Plants absorb this wavelength most efficiently, making it vital for grow lighting, horticulture, and photobiology research.
730 nm steps into the near‑infrared region, almost invisible to the eye. It’s widely used for controlling plant photoperiods, triggering flowering, and specific optical experiments.
810 nm is also near infrared, invisible to the eye but with greater penetration power—commonly used for therapy devices, deep‑tissue illumination, and industrial detection.
850 nm is a typical infrared band, widely used in night vision, security cameras, and industrial sensors, providing invisible illumination for surveillance.
940 nm is deeper infrared, almost completely invisible, with enhanced stealth—ideal for high‑end surveillance, infrared imaging, remote control, and specialized detection systems.
From visible red to near‑infrared and deep infrared, each wavelength offers unique value—this versatility is why LED strips serve so many different fields.
Where Are These Light Sources Most Suitable? Find the Best Match for Your Application
Application
How They Are Used
Features & Benefits
Research & Lab Work
Red LED strips are used as spectrum indicators and auxiliary light; near‑infrared is used for hidden excitation and optical testing
Visible red is easy to observe; infrared meets special experimental needs
Plant Growth
Deep red accelerates photosynthesis; near‑infrared adjusts flowering time; ideal for both home and commercial grow setups
Flexible installation, suitable for racks or greenhouses
Health & Therapy
Red light targets surface tissues; near‑infrared penetrates deeper, used in therapy beds, handheld or wearable devices
Combined wavelengths achieve comprehensive care
Night Vision & Security
Infrared strips mounted on cameras deliver clear images even in darkness
Low‑power options for home, high‑power for outdoor long‑range
Industrial Detection
Infrared strips built into sensors or inspection machines provide stable, concealed illumination
Meets needs of production lines and precision inspections
Specialized Fields
Infrared strips in niche areas like remote control or communications provide unique solutions
High concealment, customizable for many scenarios
Want to Choose the Right Product? See How These Models Can Power Your Projects
Below are six groups of popular LED strips, each group covering one wavelength with two models (SMD2835 and SMD5050) to help you compare and find your best fit.
🔴 635 nm Red Light Strips: Clear Indicators and Decorative Lighting
635 nm emits bright visible red, perfect for clear visual cues:
  • Spectrum indicators and teaching demonstrations
  • Industrial equipment status lights and warning strips
  • Exhibit halls, stage outlines, or signage borders
💡 Example Products:
SMD2835 635 nm Red LED Strip – Single‑chip design, low power consumption, flexible PCB, ideal for lab benches and signage edges
SMD5050 635 nm Red LED Strip – Triple‑chip configuration, higher brightness for long‑distance visibility in industrial and exhibition settings
🌱 660 nm Red Light Strips: Boost Plant Growth
660 nm deep red is critical for photosynthesis and healthy growth:
  • Small grow racks, home horticulture setups
  • Teaching experiments and lab tests
  • Greenhouses and large‑scale farming
💡 Example Products:
SMD2835 660 nm Plant Grow Strip – Even light output, flexible layout, easy to mount on small cultivation structures
SMD5050 660 nm Plant Grow Strip – High‑power design, ideal for greenhouses and large planting areas
🌸 730 nm Near‑Infrared Strips: Control Photoperiods and Flowering
730 nm is near infrared, invisible to the eye, yet powerful for growth cycles:
  • Nighttime supplemental lighting to trigger flowering
  • Photoperiod adjustment for higher yields
  • Horticultural experiments and greenhouse use
💡 Example Products:
SMD2835 730 nm Near‑IR Strip – Low power, flexible PCB, perfect for home gardens and research racks
SMD5050 730 nm Near‑IR Strip – Triple‑chip, high output for wide coverage in greenhouses and horticultural projects
💆♀️ 810 nm Near‑Infrared Strips: Deep Illumination for Therapy
810 nm penetrates tissues, suitable for health and wellness devices:
  • Wearable gadgets and portable therapy units
  • Therapy beds and recovery pods for muscle and tissue care
  • Deep‑illumination medical devices
💡 Example Products:
SMD2835 810 nm Therapy Strip – Flexible, cuttable, easy to embed in compact health devices
SMD5050 810 nm Therapy Strip – High output and durability, ideal for large professional therapy equipment
🌌 850 nm Infrared Strips: Night Vision and Security Essentials
850 nm is the most common infrared band for night vision:
  • Home surveillance cameras and indoor night‑vision setups
  • Factory, warehouse, and parking lot security
  • Wildlife night filming and infrared motion systems
💡 Example Products:
SMD2835 850 nm Infrared Strip – Compact and versatile, great for home cameras, delivers clearer night images
SMD5050 850 nm Infrared Strip – Triple‑chip high power, supports long‑distance night vision for outdoor and industrial uses
🔒 940 nm Infrared Strips: Stealth Lighting for Specialized Needs
940 nm infrared is almost completely invisible, perfect for high‑concealment use:
  • Smart home infrared sensors
  • High‑end surveillance systems and industrial inspection
  • Remote control receivers and special scientific setups
💡 Example Products:
SMD2835 940 nm Infrared Strip – Low power, highly discreet, easy integration into compact devices
SMD5050 940 nm Infrared Strip – High output with stable performance, built for professional engineering and special surveillance
Closing Note
From visible red to deep infrared, each wavelength carries unique potential. Whether you’re building a lab platform, setting up a green grow system, developing health devices, or upgrading security, the right LED strip model can make your project far more efficient.
At LEDLightsWorld, we strive to offer diverse, professional lighting solutions for every need. We hope this detailed guide helps you feel confident and inspired when choosing among the many options.
✨ Light up your project with the perfect LED strip. If you need further technical support or product recommendations, feel free to reach out to us anytime!
Ir (infrared) led strips
