S1616 16×16mm Silicone Neon Light Housing – IP67 Waterproof LED Channel Demo
Key Highlights in This Video
- 16 × 16 mm silicone neon light housing for high-diffusion LED lighting
- Designed for 12 mm LED PCB width
- IP67 waterproof level suitable for both indoor and outdoor installations
- Strong, flexible silicone material allows shaping along curves and outlines
- Comes in a 16.4 ft (5 m) roll for extended lighting projects
- Provides bright, uniform neon-style illumination without hotspots
- Model: S1616 Neon Light Housing
- Dimensions: 16 × 16 mm
- Compatible PCB Width: 12 mm
- Material: Flexible silicone
- Waterproof Rating: IP67
- Length: 16.4 ft (5 m) per roll
- Use Cases: Architectural contour lighting, signage outlines, outdoor decorative lighting
Frequently Asked Questions
- Q: Is the S1616 housing suitable for outdoor lighting?
- A: Yes, its IP67 waterproof rating ensures excellent resistance to moisture and dust.
- Q: What LED strip size fits this housing?
- A: It is compatible with LED strips using a 12 mm PCB.
- Q: Can the silicone housing be bent?
- A: Yes, the flexible silicone allows curved and shaped installations.
- Q: What are common applications?
- A: It is ideal for signage borders, architectural accent lines, and decorative outdoor lighting.
