1. Define Your Requirements
Brightness:
Indoor: 800–2,000 nits.
Outdoor LED Digital Poster
Indoor LED Poster Display
3. Structure & Installation
Protection Rating:
Mounting Options: Wall-mounted, ceiling-hung, freestanding, or embedded
