Item
Self-Adhesive Transparent LED Film
Holographic Invisible LED Film
| Photo |
| PCB |
Use flexible transparent film (such as PET or PI material) as the substrate, and embed micro LED chips (Micro LED or Mini LED) into it with high density.
It is a whole hollow PCB board, using a LED lamps with IC drive integrated in |
| Structure |
The LED layer are between 2 layer of gel, the screen surface is waterproof (not the control board part) |
The LED is naked at surface, having good heat dissipation. |
| Flexibility |
Better flexibility, can be rolled into a small cylinder |
Suitable for fitting large arcs, can not bend excessively |
| Brightness |
Regular is 2000-2500nits, can make into 4000nits for P6.25 P8, P10, P15, P20 |
Regular is in 3500nits, can be adjusted to 5000ntis the max |
| Pixel Pitch |
5mm, 6.25mm, 8mm, 10mm, 15mm, 20mm |
3.91mm, 6.25mm |
| Sizes |
Standard size in 1000mm wide, can be customized to other lengths (has limitation), but need to charged customization fee.
Standard size has 1000mm, 1250mm, 1500mm. And can be cut every 1LED row.
| Transparency Rate |
Physical &Visual >90% |
Physical >80% ; Visual Transparency Rate >90% |
| Installation |
Self-Adhesive by using water. The gel layer are anti-UV ones, which are sticked by water . The longer they are pasted, the stronger they are. |
Need to use adhesive tape, what we use is 3M300LSE,Automotive grade high temperature resistance. |
