The Comparison between SMD3528, SMD5050, SMD5630, SMD2835 and SMD4014 LED Strip Lights
About Different Strips Models and their Parameters
  First, let me have a short look for different SMD LED the component. Below are some of the LEDs that are commonly used in LED Strip Lights.
The popular spec. for them we used in our strips:
SMD3528  (rated 0.06W/LED)
SMD2835  (rated 0.2W/LED)
SMD5050  (rated 0.2W/LED)
SMD5730/5630  (rated 0.5W/LED)
SMD3014 (rated 0.1W/LED)
SMD4014 (rated 0.2W/LED)
SMD3030 (rated 1W/LED)
SMD5050 RGB (rated 0.2W/LED)
SMD5050 RGBW (rated 0.2W/LED)
SMD5050 Dual White (rated 0.2W/LED)
The popular LED Flexible Strip models:
Strip Model LED Density Rated Power Available Colors PCB Width Light Emitting CCT
Lumen Output
per Meter
SMD3528-150 30LED/Meter 2.4W/Meter
White, Red, Green, Blue, Yellow,
Pink, Purple, Orange,IR, UV
8mm Top-Emitting 2700K-6500K 100-150LM
SMD3528-300 60LED/Meter 4.8W/Meter
6mm/8mm Top Emitting 2700K-6500K 200-300LM
SMD3528-600 120LED/Meter 9.6W/Meter
Pink, Purple,Orange, IR, UV
5mm/8mm Top Emitting 2700K-6500K 400-600LM
SMD3528-1200 240LED/Meter 19.2W/Meter
15mm Top Emitting 2700K-6500K 800-1200LM
SMD2835-300 60LED/Meter 12W/Meter
8mm Top Emitting 2700K-6500K 1000-1200LM
SMD2835-600 120LED/Meter 18W/Meter
8mm Top Emitting 2700K-6500K 2000-2400LM
SMD5050-150 30LED/Meter 7.2W/Meter
White, Red, Green, Blue, Yellow, Pink, Purple,
Orange, Orange,IR, UV, RGB, RGBW, Dual White
10mm Top Emitting 2700K-6500K 450-550LM
SMD5050-300 60LED/Meter 14.4W/Meter
10mm Top Emitting 2700K-6500K 900-1100LM
SMD5050-600 120LED/Meter 28.8W/Meter
15mm Top Emitting 2700K-6500K 1800-2200LM
SMD5630-300 60LED/Meter 12W/Meter White, Red, Green, Blue, Yellow, Pink, Purple 10mm Top Emitting 2700K-6500K 1000-1200LM
SMD3014-300 60LED/Meter 12W/Meter White, Red, Green, Blue, Yellow, Pink, Purple 4mm/8mm
Top Emitting /
Side Emitting
SMD3014-600 120LED/Meter 18W/Meter White, Red, Green, Blue, Yellow, Pink, Purple 4mm/8mm
Top Emitting /
Side Emitting
SMD4014-300 60LED/Meter 12W/Meter White,Red, Green, Blue, Yellow, Pink, Purple 8mm Top Emitting 2700K-6500K 1000-1200LM
