What is LED Spotlights?
LED Spotlights, also known as projection lights, are mainly used for architectural decoration lighting purposes and the trade space lighting with more decorative ingredients. Usually its appearance is circle or well, and considering of heat reasons, there are still some differences between LED Spotlights and traditional Spotlights.
Most LED Spotlights’ power is 1W , there are also a small number of companies due to the cooling technologies handled well, providing the 3W or higher power LED. These high power LEDs are suitable for large occasions Spotlights lighting and building lighting. Through the built-in microchip, LED Spotlights can be used to achieve a gradual transition, color flashing, random flashing, alternating gradient dynamic effects in applications of minor projects and buildings.
Application Places of LED Spotlights:
Suitable for single building, lighting of exterior wall, building light outside through lighting, indoor local lighting, green landscape lighting, billboard, medical culture and specialized facilities such as lighting, bar, discos and other entertainment atmosphere lighting and so on.
Features of LED Spotlights:
  1. With high purity aluminum reflector plate, the Spot Lights can provide the most accurate beam, and the best reflection effect.
    2. Symmetric narrow-angle, wide-angle and asymmetric light distribution system built in.
    3. Lamp replacement from behind, easy to maintain.
    4. The scale plate lamps accompanied, easy to adjust the beam angle.
What is LED Floodlights?
The LED Floodlights is an irradiated uniformly point source in all directions, its illuminated area can be adjusted flexibly in the scene.Floodlights can shine out light from a specific point to all directions evenly, similar to light bulbs and candles. Since the Floodlights illuminated area is large, so the Floodlights effect of irradiation is very easy to guess, and there are many auxiliary purposes in using Floodlights, for example, placing the Floodlights  close to an object, you can see bright light on the surface of this object.
Application Places of LED Floodlights:
Suitable for workshop, factory, warehouse, highway toll stations, gas stations, supermarkets, exhibition halls, stadiums, construction sites, mining areas and other places of lighting required.
Features of LED Floodlights:
1, High thermal conductivity, low luminous decay, pure light color, no weightfilm;
2, Longer life time of the light source and power than normal Floodlights;
3, Usually up to IP65 standards, corrosion resistance, waterproof, dustproof performance is good;
4, High energy-saving effect: equipped with high-power LED light and high-efficiency power supply, the use of LED FloodLights can save 80% energy or more compared with the sodium lights
5, No pollution, no lead, mercury and other pollution elements, there is no pollution to the environment;
6, Good color, more real: LED Floodlights support various light colors optional to meet the different needs of the environment, eliminating the repressed emotions from traditional lamp color temperature ;
7, Excellent decorative effect, many color selections of the appearance, simple to install, easy to dismount.
