From simply “powering on a module” to having a fully functional LED display, the process requires much more than just LED panels. A reliable system is the result of power supplies, control cards, cabling, enclosures, and software working together. Understanding the role of each accessory not only ensures stability but also makes installation and maintenance much easier.
Below is a step-by-step breakdown of the key components you’ll need when putting together a complete LED screen.
LED Module Selection
The LED module is the core display unit, consisting of LEDs, driver ICs, PCB, power, and data interfaces.
Pixel Pitch
Common options: P2.5 / P3.91 / P4.81 / P5 / P10
Principle: the closer the viewing distance, the smaller the pixel pitch. Outdoor large screens often use P5 or above.
Module Size & Interface
Standard sizes: 320×160 mm, 240×120 mm
Data interface: HUB75, standard input DC 5 V
Assembly: module dimensions must match the cabinet, e.g., a 640×480 mm cabinet fits four 320×160 mm modules.
Brightness & Protection
Indoor: 800–1200 nits is usually sufficient
Outdoor: ≥5000 nits and IP65 rating for water and dust protection
Maintenance Method
Front access: modules can be removed from the front with magnetic tools; ideal for wall-mounted or embedded installations
Rear access: easier disassembly, common in rental cabinets with backstage access
Power Supplies & Capacity Planning
LED modules operate on stable 5 V DC power, which requires reliable power supplies.
Power Calculation
Max power per module × number of modules = total load
Add 20–30% headroom for stability
Example: one 320×160 mm indoor module consumes ~30 W. 100 modules = 3,000 W → recommended supply ≥3,600 W
Typical Power Cables
5 V branch cables:
1-to-2 split, 18AWG + 2.5 mm²
Lengths: 350 mm / 750 mm / 850 mm
UL standard (gray/brown) or red-black national standard
DC power cords:
3×2.5 mm² or 3×14AWG
Lengths: 600 / 800 / 1200 mm
With O-ring terminals for secure connections to power supplies or receiving cards
Power Supply Models (Examples)
LRS-350-5: versatile indoor option
UHP-350-5: slim, efficient, ideal for thin cabinets
RSP-320-5: designed for damp or semi-outdoor environments
Receiving Cards & Signal Loading
The receiving card is the “nerve ending” of the control system, distributing incoming data to each module.
Key Specs
Maximum load capacity (e.g., 512×256 pixels)
Output type: HUB75 / HUB75E
Refresh rate: ≥1920 Hz; premium models up to 3840 Hz for smoother video
Monitoring functions: some models track voltage, temperature, and status
Deployment
Common setup: one receiving card per cabinet → cleaner wiring and easier troubleshooting
HUB distribution boards are often used for flexible module connections, compatible with NovaStar, ColorLight, Huidu systems
Sending Devices
The sending device is the entry point for content. Options vary based on screen size and complexity:
Sending Cards: simple PC-driven setups for small, fixed-resolution displays
Sending Boxes: external devices with multiple input ports, easier wiring, common in rental setups
Video Processors: advanced scaling, multi-window, and signal switching, widely used for events, exhibitions, and stage setups
Cabling & Connections
Stable cabling is critical for both power and data integrity.
Flat Ribbon Cables (module ↔ receiving card)
HUB75 standard
16-pin: 400 / 600 / 800 / 1000 / 1200 mm
20-pin: 600 / 900 mm
Network Cables (sending ↔ receiving cards)
Cat5e molded cables
Standard lengths: 1 m / 5 m / 10 m
Molded ends ensure reliable, oxidation-resistant connections
Power Distribution
Keep cables short to minimize voltage drop and heating
For outdoor setups: add grounding, waterproofing, and cable protection
Cabinets & Installation
Cabinet Types
Die-cast aluminum: lightweight, precise, seamless; ideal for rental
Sheet metal: cost-effective, commonly used in fixed installations
Installation Methods
Wall-mounted / embedded: save space, often used in meeting rooms or retail signage
Hanging / stacking: suitable for rental stages, concerts, exhibitions
Structural Details
Positioning pins, quick locks, and cable routing significantly improve assembly efficiency and visual consistency
Control PC & Software
Role: media playback, screen control, parameter setup
Recommended Hardware: stable PSU, dedicated GPU, and SSD for smooth playback
Modes:
Synchronous: real-time display of PC content
Asynchronous: offline playback with scheduling, common for advertising displays
Application Examples
Model |
Typical Use Case |
Why It Fits |
Notes & Pairing Tips |
Indoor / semi-outdoor |
Reliable 5 V PSU, versatile |
Allow 20–30% headroom; works with 320×160 mm HUB75 modules |
Slim cabinets |
Thin, efficient, low noise |
Ideal for high-brightness projects; ensure ventilation |
4.5 V module setups |
Stable 4.5 V output |
Use only when modules require 4.5 V; confirm specs first |
Humid / heavy load |
Moisture-resistant, steady |
Semi-outdoor installs: pair with sealed box, desiccant, grounding |
Budget-friendly builds |
Certified, supports common 5 V loads |
Size according to total power; compatible with mainstream systems |
This way, we can see that a complete LED display requires not only modules, but also power supplies, control systems, cables, cabinets, and software. With the right accessories and careful planning, you’ll build a screen that’s stable, efficient, and easy to maintain.
