In the field of outdoor LED displays, stability and visual performance are equally important. The OD-PM Series outdoor LED modules stand out with exceptional protection design, high brightness, and a wide range of pixel pitch options, making them an ideal choice for outdoor advertising, stage setups, and commercial display projects. Whether under scorching sunlight or in rain and snow, the OD-PM Series ensures clear images and vivid colors, safeguarding the performance of your outdoor display projects.
① Flexible Front and Rear Maintenance Design – Reduce Maintenance Costs
The OD-PM Series supports both front and rear maintenance, with modules secured by a combination of magnetic mounts and screws, allowing for quick on-site removal and replacement.
Front Maintenance: Ideal for screens installed at height, enabling module replacement or inspection without removing the entire display, significantly reducing maintenance time and labor costs.
Rear Maintenance: Suitable for installations with sufficient space at the back, allowing technicians to conveniently inspect circuits, cabling, and module details from behind.
This dual-maintenance approach greatly improves service efficiency, reduces the complexity and costs of daily maintenance, and is particularly suited for public spaces and outdoor environments that operate for long hours.
② High Brightness and Full Protection – Built for Harsh Outdoor Environments
Outdoor LED displays must withstand challenges such as direct sunlight, heavy rain, and dust. The OD-PM Series is designed with these conditions in mind:
IP65 Full Protection: Fully dustproof and waterproof modules ensure stable operation in rain, sandstorms, or humid conditions.
High-Brightness Display: Premium LED chips deliver brightness levels of 5,500–6,800 nits, maintaining clear visibility even in intense sunlight.
Durable Cabinet Structure: Made from high-strength alloy for stability and excellent heat dissipation, ensuring long-term, efficient performance.
Weatherproof and Anti-Corrosion Treatment: Anti-corrosion coating and sealed construction improve resistance to aging and salt spray, making it suitable for coastal areas and industrial zones.
③ Versatile Pixel Pitches and Sizes – Designed for Different Applications
The OD-PM Series offers a wide range of pixel pitches from P4 (4 mm) to P10 (10 mm), meeting needs from close-up, detail-rich displays to large-format, long-distance viewing.
Small Pixel Pitch Models: High pixel density with sharp, accurate color reproduction; ideal for high-end retail storefronts, commercial street advertising, and TV studio backdrops where detail is essential.
Medium and Large Pixel Pitch Models: High brightness and wide coverage; even from a distance, images remain sharp and vivid—perfect for large outdoor billboards, sports stadiums, and transportation hubs.
Two cabinet sizes are available: 320×320 mm standard modules deliver high color uniformity, precision alignment, and strong visual coherence for large seamless splicing projects, while 250×250 mm smaller modules are lightweight and flexible, ideal for creative installations like pillar screens, curved displays, and areas with limited space.
④ Advanced Display Performance and Technical Advantages
High Refresh Rate Technology: Some models reach up to 3,840 Hz, effectively eliminating flicker for smooth, natural visuals—even under high-speed camera capture or live broadcasting, with no ripples or ghosting.
High Color Depth: 16-bit color processing delivers richer gradients and more precise tonal transitions. From highlights to shadow details, every element is faithfully reproduced, creating a vivid, layered image.
Wide Viewing Angles: Approximately 140° horizontal and vertical viewing ensures consistent brightness and color from different angles, maximizing audience coverage and viewing comfort.
High-Precision Seamless Splicing: Accurate pixel alignment and strict color calibration result in virtually invisible seams, providing a strong sense of visual continuity—ideal for high-end conference backdrops, large-scale stage performances, and premium brand displays.
💡 Recommended Models from the OD-PM Series
Resolution & Pixel Density: 80×80 dots, ~62,500 pixels/㎡ for outstanding detail clarity.
Brightness: ≥5,500 nits, clear even in strong light.
Optimal Viewing Distance: ~4 m for both near and mid-range viewing.
Key Advantages: Combines high resolution and brightness with accurate color reproduction—perfect for detail-focused premium projects.
Typical Applications: High-end retail storefronts, shopping mall entrances, brand showcase walls.
Resolution & Pixel Density: 64×64 dots, ~40,000 pixels/㎡ for balanced image quality and cost efficiency.
Brightness: ≥5,500 nits, visible in direct sunlight.
Optimal Viewing Distance: ~5 m for mid-range viewing with budget-friendly performance.
Key Advantages: High value, easy maintenance, suitable for large-scale deployments.
Typical Applications: City pedestrian street advertising, community notice boards, commercial plaza information screens.
Resolution & Pixel Density: 48×48 dots, ~22,500 pixels/㎡ for large screens and long-distance viewing.
Brightness: ≥6,000 nits, built for all-weather visibility.
Optimal Viewing Distance: ~6–8 m for maximum visual impact.
Key Advantages: High brightness, wide viewing angles, and durable stability for continuous operation.
Typical Applications: Sports stadiums, transport hubs, city square mega-screens.
Resolution & Pixel Density: 52×52 dots, ~43,264 pixels/㎡ for compact, flexible installations.
Brightness: ≥5,500 nits for clear outdoor visibility.
Optimal Viewing Distance: ~4–5 m for balanced clarity and versatility.
Key Advantages: Lightweight and adaptable to limited spaces or creative shapes.
Typical Applications: City pillar advertisements, decorative light boxes, creative displays on commercial streets.
As the outdoor digital display market continues to evolve, choosing a product that combines stable performance, easy maintenance, and exceptional visual quality is key to project success. The OD-PM Series outdoor LED modules, with their advanced technology and user-friendly design, offer reliable and long-lasting performance. Whether for building a premium brand presence or installing a large-scale public information screen, OD-PM can add vibrant impact and enhance the overall value of your project.
If you would like to learn more about product details or discuss a custom solution, feel free to reach out. I will be happy to provide you with sincere advice and professional support to help make every project a success.
