Different Types of LED Strip Connectors and Their Compatible LED Strips
When installing LED strips, choosing the right connectors and cables is just as important as selecting the strip itself. Think of connectors as puzzle pieces—only the right match will ensure steady illumination, long lifespan, and safe performance. Many common issues, such as strips lighting up only halfway, flickering, or overheating, are often related to mismatched connectors. In this guide, we’ll walk through the most common types of LED strip connectors, how they fit different strip designs, and practical tips for installation.
1. Matching Connector Size to Strip Width
The width of an LED strip is the first factor to consider when choosing a connector. Common widths are 8mm, 10mm, and 12mm. If the connector doesn’t match, you risk loose contact or premature failure.
👉 Tip: Measure the strip width with a caliper before purchasing to avoid mismatches.
2. Specialized Connectors for COB Strips
COB (Chip on Board) strips provide continuous, dot-free light, but they require specific connectors because of their thinner base and higher heat output.
When COB strips are installed in aluminum channels, bulky connectors can prevent the cover from closing. In these cases, low-profile transparent connectors such as track-style connectors are recommended.
3. Single-Color, Dual White, and Multi-Color Options
The number of colors a strip supports determines the connector type:
  • Single-color strips: Require only 2 pins.
  • Dual white (CCT) strips: Switch between warm and cool white with 3-pin connectors.
  • RGB, RGBW, and RGBCCT: Require 4-pin, 5-pin, or 6-pin connectors respectively.
⚠️ Using the wrong connector (e.g., fewer pins than required) can cause certain colors or functions to fail.
4. Power Cables and Extension Wires
Once strips are connected, power cables and extensions ensure steady operation:
For outdoor setups, waterproof solutions like DC waterproof connectors or 4-pin waterproof RGB connectors are essential.
5. Installation Details to Pay Attention To
When installing LED strips with connectors, there are a few small details that are often overlooked:
  • Space allowance: If the connector is too bulky, it may prevent covers or housings from closing properly.
  • Corner connections: For L-shaped or T-shaped corners, it is recommended to use dedicated corner connectors or DIY kits to keep wiring neat and organized.
  • Test fitting: Before fixing everything in place, it’s best to temporarily combine the strip and connector to check whether the sizes and pins match, reducing the chance of rework later.
6. Useful Accessories
A few extra accessories can make installation smoother:
7. Practical Overview of Connectors and Accessories
To make it easier to find the right parts, here’s a quick reference table summarizing common connector and accessory options:
Category Recommended Products
Single-color connectors 8mm 2-pin connector / 10mm 2-pin connector
RGB / RGBW / RGBCCT 4-pin RGB connector / 5-pin RGBW connector / 6-pin RGBCCT connector
COB strip connectors 2-pin COB connector / 4-pin COB RGB connector
Power & extension cables DC power cable / DC extension with switch / RGB extension cable
Waterproof accessories DC waterproof connector / 4-pin waterproof RGB connector / end cap
DIY kits L/T-shaped connector kit / RGB splitter
Led strip connectors & cables
