With the continuous advancement of optoelectronic technology, ultraviolet (UV) and violet LED chips have become key light sources in many cutting-edge industries. From traditional printing curing, electronic packaging, and optical inspection to modern biomedical, photocatalytic, 3D printing, and anti-counterfeiting applications, UV LED chips are gradually replacing high-pressure mercury lamps and conventional UV light sources thanks to their high efficiency, long lifespan, and precise wavelength control.
In today’s integration of materials science and optical engineering, UV LEDs not only represent the direction of energy-saving and environmental protection but also fulfill the core requirements of precision manufacturing and experimental detection. Different wavelengths—such as 365nm, 385nm, and 405nm—show distinct differences in energy density, penetration, and photochemical behavior. Understanding how to choose the right wavelength and package type based on your application has become a common concern for optical designers, research engineers, and equipment manufacturers.
This article explains the wavelength principles, package structures, performance characteristics, and typical application fields of UV LED chips. Through real product examples, it provides a clear selection framework to help readers identify the most suitable wavelength for their professional use.
I. Understanding the Core Principles of UV LED Chips from a Spectral Perspective
The working principle of UV LEDs is based on photon emission through electron–hole recombination within a semiconductor material. By introducing specific doping layers into the crystal structure, the photon energy—and therefore the emitted wavelength—can be precisely controlled.
The UV spectrum is generally divided into:
UVA (320–400nm)
UVB (280–320nm)
UVC (200–280nm)
Among these, UVA is the most commonly used due to its safety, stability, and versatility. UVA chips are typically made of wide bandgap semiconductors such as gallium nitride (GaN) and aluminum gallium nitride (AlGaN), achieving a balance between optical output and heat management for stable long-term operation.
Within the UVA range, 365nm–405nm is the most widely used core segment. Its photon energy is moderate—it can effectively excite fluorescence and trigger photochemical reactions without damaging most materials. This range is well established in laboratory testing, industrial curing, and optical inspection systems.
Compared with traditional mercury lamps, UV LED chips have several advantages:
High efficiency and low heat generation, reducing energy consumption and cooling needs.
Instant start-up, no warm-up time required.
Long service life, up to tens of thousands of hours.
Precise spectral output, customizable to exact wavelength requirements.
Currently, the most common package types are SMD2835 and SMD5050, both known for high luminous intensity, strong thermal stability, and consistency. They are ideal for laboratory instruments, curing equipment, and industrial production systems.
II. The 365nm Band: A “Precision Curing Expert” of High-Energy UV Light
The 365nm wavelength delivers strong photon energy and fast response, making it the preferred light source for precision curing and inspection systems. Positioned at the lower end of the UVA spectrum, it emits highly concentrated energy with excellent penetration, ideal for initiating chemical bonds in resins, inks, and other light-sensitive materials.
It is widely used in:
Resin curing and adhesive processing
Photolithography and photoresist exposure
Fluorescence detection and skin analysis
Anti-counterfeiting and quality inspection
Because of the high energy output, this wavelength requires robust packaging and efficient heat dissipation. Therefore, most high-end chips adopt gold wire bonding and high-conductivity GaN substrates, ensuring high luminous output even at low power. Many are also paired with aluminum or ceramic bases to lower junction temperature and prolong lifespan—critical for continuous industrial operation.
Representative Product:
365–370nm UV LED Emitters (SMD2835 / SMD5050, 0.2W–0.5W)
This series features uniform output and stable peak wavelength, ideal for UV glue curing, printing inks, 3D printing resins, and biological inspection applications—highly valued in precision manufacturing and laboratory research.
III. The 385nm Band: The “All-Round Performer” for Industrial Applications
The 385nm band balances energy and stability, making it the mainstream choice in industrial curing applications.
Its photon energy is slightly lower than 365nm, but its broader spectrum and excellent heat resistance provide better energy efficiency and compatibility with diverse materials.
This wavelength has stronger transmission and is safer for long-term human exposure, making it suitable for industrial environments requiring continuous illumination. In 3D printers, electronic assembly lines, and photocatalytic systems, 385nm LEDs are favored for their balanced light output and simplified heat management.
Typical applications include:
3D printing and UV adhesive curing – enabling fast curing with fine-layer precision.
Photocatalytic coatings and air purification – activating chemical reactions to enhance catalytic performance.
UV exposure and PCB manufacturing – ensuring uniform irradiation and sharper circuit imaging.
Surface treatment and quality inspection – used in adhesive curing and coating analysis.
Recommended Product:
380–385nm UV LED Emitters (SMD2835 / SMD5050, 0.5W Gold Wire)
With concentrated spectral output and low heat generation, this series is ideal for continuous industrial operation. Its high power density and flexible packaging make it a preferred choice for automation and equipment manufacturing systems.
IV. The 395–405nm Band: A Bridge Between Ultraviolet and Visible Light
The 395–405nm range lies at the transition between ultraviolet and visible light, retaining UV excitation characteristics while producing faint violet illumination visible to the human eye.
This wavelength provides gentle radiant energy that is less damaging to materials and the human body, making it ideal for extended lighting scenarios.
In industrial applications, it activates fluorescent coatings and enhances pigment visibility.
In the lighting and entertainment industries, it is commonly used for stage lighting, fluorescent décor, and photography assistance, while in laboratories, it serves for spectral response tests and sample preparation.
395–405nm UV LED Emitters (SMD2835 / SMD5050, 0.5W Gold Wire)
This model balances curing performance and visual appeal, suitable for scientific testing, stage lighting, and creative design.
It maintains stable output intensity and color consistency, serving as an ideal bridge between functional illumination and visual artistry.
V. From Laboratory to Mass Production: Selection and Application Advice
When selecting UV LED chips, users should consider wavelength, power density, package form, and heat dissipation capacity.
Below are general recommendations for various application scenarios:
Curing / Photochemical Reaction Projects:
Choose 365nm or 380nm wavelengths for higher energy output and faster reaction rates. -
Fluorescent Detection / Stage Effects / Art Lighting:
Opt for the 395–405nm range for softer, safer, and more visually balanced light. -
Research and Education:
Use multi-band sample kits for spectral comparison and testing.
Example: 365–405nm UV LED Emitters Sample Pack (100pcs)
VI. UV LED Chip Series Comparison and Purchase Reference
| Product Model | Recommended Applications |
| UV365-SMD2835/5050 | Curing, fluorescence detection, skin analysis |
| UV385-SMD2835/5050 | Industrial curing, photocatalysis, 3D printing |
| UV400-SMD2835/5050 | Stage lighting, fluorescent décor, visual inspection |
| UV-Mix-SamplePack | Spectral testing, educational research, system evaluation |
Conclusion: The Precision Source of Spectral Technology
The rise of UV and violet LED chips marks a transformation from conventional mercury lamps toward high-efficiency, low-energy, and wavelength-controllable light sources.
From high-energy 365nm curing to 405nm fluorescence excitation, each wavelength carries a distinct scientific and industrial mission.
Selecting the right UV LED chip means achieving the perfect balance between efficiency, precision, and safety, paving the way for more possibilities in research, manufacturing, and creative applications.
