In digital signage, no single product fits every use case.
As LED poster displays become increasingly common in retail, events, and commercial environments, the most frequent question we hear is:
“Which LED Poster Display is right for me?”
At LEDLightsWorld, we created the EP Series LED Poster Displays based on one clear principle: different environments require different solutions.
Whether you’re building a pop-up booth, outfitting retail chains, organizing touring events, or creating high-impact window displays, your needs for display size, power options, brightness, structure, and portability can vary widely. That’s why we developed over 10 distinct sub-series — each engineered for specific usage scenarios.
This article breaks down each EP model: what it’s made for, what makes it unique, and how it compares to others — helping you make an informed decision, fast.
🔹 EP-B Series — Entry-Level, Non-Splicing Simplicity
Best for: Retail promotions, standalone displays, budget-friendly projects
Key Features:
640×1920 mm screen, standalone, non-spliceable
Aluminum frame with acrylic front
Indoor use, plug-and-play
Brightness >600 nits
Why choose it:
Simple to deploy, easy to operate, perfect for first-time digital signage users or compact display areas.
Compared to EP-S:
EP-B is lighter and more affordable but lacks modular expansion.
🔹 EP-S Series — Modular Splicing for Larger Visual Walls
Best for: Chain stores, wall displays, event booths
Key Features:
640 / 960×1920 mm sizes
Screw-mounted modular design
Acrylic front, plug-in power
Indoor use, supports cloud content control
Why choose it:
Designed for scalable setups where multiple screens combine into a seamless unit.
Compared to EP-B:
More flexible but slightly more complex to set up.
🔹 EP-GOB Series — Rugged and Rental-Ready
Best for: Rental companies, touring setups, fast-paced deployment
Key Features:
640×1920 mm, spliceable
GOB-coated surface for durability
Flip-open magnetic frame
Indoor, >600 nits
Why choose it:
Built for heavy usage and transport. GOB protection and magnetic assembly allow quick setup and longer lifespan.
Compared to EP-S:
Faster to deploy and tougher, though priced higher.
🔹 EP-BAT Series — Cordless Display, Battery-Powered Freedom
Best for: Events, venues without outlets, temporary installations
Key Features:
Same form factor as EP-S, supports splicing
Internal rechargeable battery
Acrylic front, indoor use, >600 nits
Why choose it:
Freedom to deploy anywhere, without being tied to an outlet. Ideal for malls, exhibits, or pop-ups.
Compared to EP-S:
Same structure, different power source.
🔹 EP-F Series — Foldable Frame, Made for Transport
Best for: Touring events, roadshows, space-constrained logistics
Key Features:
Foldable rear-hinged frame
GOB protective surface
Indoor use, plug-in, >600 nits
Why choose it:
Compact and efficient for transport and storage. Fold-and-go structure reduces shipping volume.
Compared to EP-GOB:
Similar performance but much better portability.
🔹 EP-TR Series — Tri-Fold for Immersive Presence
Best for: Brand entryways, large-format visual statements, showrooms
Key Features:
1280×1920 mm tri-fold (W-style) structure
GOB protection, indoor only
600 nits brightness
Why choose it:
Offers wide visual coverage and strong spatial presence.
Compared to EP-F:
Less portable but far more visually impactful.
🔹 EP-OD Series — Outdoor-Grade with All-Weather Durability
Best for: Exterior storefronts, outdoor signage, public spaces
Key Features:
Mesh cover, water-resistant structure
Outdoor-ready, >5000 nits
Why choose it:
Handles direct sunlight, rain, and variable conditions. Built for real outdoor environments.
Compared to indoor models:
Only true outdoor option in the series.
🔹 EP-M Series — All-in-One Rental Kit with Lift
Best for: High-efficiency rentals, mobile crews, quick deployment
Key Features:
1×2.25 m or 1×4 m sizes
Remote-controlled lift system
Mesh cover, plug-in, >600 nits
Why choose it:
Turnkey display kit with height adjustment and compact transport case. Perfect for plug-and-play users.
Compared to EP-F / EP-TR:
Fully integrated deployment, suited for rental businesses.
🔹 EP-T Series — Transparent for Creative Visual Blending
Best for: Luxury retail, window displays, creative studios
Key Features:
1×2 m or 2×2 m transparent panels
Indoor use, brightness 3000–5000 nits
Why choose it:
Displays visuals without blocking background views — great for layering digital over physical objects.
Compared to standard displays:
Not spliceable, but visually unique.
🔹 EP-RS Series — Rollable, Ultra-Portable for Field Teams
Best for: Pop-ups, educational outreach, flexible marketing
Key Features:
0.5×1 m or 1×2 m
Rollable frame, GOB surface
Plug-in, >600 nits
Why choose it:
Carry it, unroll it, and go. Built for teams that move often and need minimal setup.
Compared to EP-F / EP-BAT:
Most portable, fastest to deploy.
✅ Match the Right Display to the Right Job — EP Series Use Case Guide
Use Case |
Recommended Series |
Standalone setup / entry-level use |
EP-B, EP-RS |
Modular video wall setup |
EP-S, EP-GOB |
Rentals / frequent setup & teardown |
EP-GOB, EP-M |
Locations without power outlets |
EP-BAT |
Lightweight / portable deployment |
EP-F, EP-RS |
Premium brand visual impact |
EP-TR, EP-T |
Outdoor, all-weather signage |
EP-OD |
Transparent window displays |
EP-T |
Plug-and-play, fast deployment |
EP-M, EP-B, EP-RS |
Creative storytelling & blended visuals |
EP-T, EP-TR, EP-RS |
🎯 Final Thought: Every EP Series Exists to Solve a Real Deployment Problem
We didn’t create the EP Series just to offer more models — we built it to solve real-world challenges in digital signage deployment.
Whether you’re dealing with limited power, tight spaces, frequent transport, or a high-end showroom, there’s an EP Poster Display designed exactly for that need. It’s not about overengineering — it’s about offering the right tool for the job.
So start with your scenario — and you’ll find the perfect fit. And if you’re still not sure, our product specialists are always here to help you make a confident, informed decision.
