1. Define Your Requirements
Brightness:
Indoor: 800–2,000 nits.
Outdoor LED Digital Poster
Indoor LED Poster Display
Comparison Between P1.86, P2, P2.5 and P3.076 : The smaller the spacing, the finer and clearer the picture will be when watching from the same distance and playing the same content. (p.s. Please ignore the color difference caused by different batches of products here, because different batches of lamp beads are used.)
3. Structure & Installation
Protection Rating:
Plug to wall outlet LED Poster
