In integrated LED applications, red and infrared LED beads are widely used in medical devices, horticultural lighting, night vision systems, sensors, and industrial detection. Unlike LED strips, LED beads serve as core light-emitting components, with a focus on precise wavelength control, stable encapsulation, and electrical compatibility.
This guide explores the characteristics, packaging types, application scenarios, and selection tips across wavelengths ranging from 635nm to 940nm.
📌 Application Scenarios by Wavelength
- 635nm (Visible Red): Bright, responsive light. Ideal for status indicators, display modules, and educational instruments.
- 660nm (Deep Red): Optimized for chlorophyll-a absorption; used in plant growth and photobiological research.
- 730nm (Near-Infrared): Invisible to the eye; supports photoperiod control and flowering cycles in horticulture.
- 810nm (Near-Infrared): Strong tissue penetration; used in medical therapy and wellness devices.
- 850nm (Infrared): Standard IR wavelength for night vision systems; slightly visible as a faint red glow.
- 940nm (Infrared): Fully invisible; ideal for covert IR illumination, remote controls, and smart sensors.
📦 Package Types & Performance Overview
| Wavelength | SMD2835 Features | SMD5050 Features |
| 635nm | Single-chip, low power, fast response. Ideal for indicators. | Triple-chip, high brightness for signage and displays. |
| 660nm | Designed for grow lights; compact and efficient. | High output, great for commercial horticulture. |
| 730nm | Low power for spectrum balancing. | High irradiance; supports photoperiod lighting. |
| 810nm | Focused beam; ideal for compact medical tools. | Stable, long lifespan for large therapy devices. |
| 850nm | Suitable for IR sensors and short-range security. | High-power IR for surveillance and vision systems. |
| 940nm | Low leakage current for smart controls. | High integration for invisible illumination. |
🧩 Application Areas & Benefits
| Application | Suitable Wavelengths | Key Advantages |
| Research & Education | 635 / 660 / 730 | Combines visible and near-IR light for learning and demonstrations. |
| Horticulture | 660 / 730 | Enables precision light control in plant growth modules. |
| Medical Devices | 810 | Delivers deep penetration with low heat for light therapy. |
| Night Vision | 850 / 940 | Integrated into cameras; 940nm provides full invisibility. |
| Industrial Sensing | 850 / 940 | Reliable output for detection systems and smart interfaces. |
🎯 How to Choose the Right Red/Infrared LED Bead
- Need a visible indicator? Choose 635nm – bright, immediate feedback.
- Building grow lights? Use 660nm + 730nm – photosynthesis + flowering control.
- For therapy tools? Pick 810nm – optimal for deep tissue treatment.
- Need night vision or smart sensors? Choose 850nm (visible IR) or 940nm (invisible IR).
🔍 LED Beads vs. LED Strips: Key Differences
| Attribute | LED Beads | LED Strips |
| Form Factor | Single emitters, discrete units | Continuous strips with multiple emitters |
| Integration | Soldered to PCBs or modules | Peel-and-stick deployment |
| Lighting Control | Beam-focused, directional | Even light distribution |
| Precision | High wavelength accuracy | Moderate accuracy, built for coverage |
🔧 Recommended Models by Wavelength
🔴 635nm Red LED Beads – Visual Indicators & Displays
- SMD2835 635nm: Compact, fast-responding for lab kits and control panels
- SMD5050 635nm: High-intensity for industrial and exhibition signage
🌱 660nm Red LED Beads – Photosynthesis Boosters
- SMD2835 660nm: Efficient and slim; ideal for small grow modules
- SMD5050 660nm: High-power output for vertical farming and commercial setups
🌸 730nm IR LED Beads – Flowering Cycle Control
- SMD2835 730nm: Low power for precision spectral balance
- SMD5050 730nm: High irradiance, ideal for automated horticulture systems
💆♀️ 810nm IR LED Beads – Deep Light Therapy
- SMD2835 810nm: Narrow beam, great for wearables and handheld tools
- SMD5050 810nm: Long lifespan, fit for therapy beds and face masks
🌌 850nm IR LED Beads – Night Vision Standard
- SMD2835 850nm: Compact, suited for IR sensor modules
- SMD5050 850nm: High output for surveillance and security lighting
🔒 940nm IR LED Beads – Invisible & Smart
- SMD2835 940nm: Low energy use, for remotes and smart devices
- SMD5050 940nm: Stealthy high integration, ideal for covert surveillance
🏁 Final Thoughts
From visible red to deep infrared, each LED bead wavelength serves a unique and powerful function in modern lighting systems. Whether you're designing scientific instruments, building plant growth modules, developing therapeutic devices, or creating IR-based automation and sensing, selecting the right wavelength and package type is essential for success.
💬 Need Help Choosing?
Reach out to the LEDLightsWorld team for datasheets, design support, and product recommendations.
👉 Illuminate your innovation—start with the right LED bead.
