S1010 Neon Light Housing – 10×10 mm IP67 Silicone LED Channel Demo
Discover the S1010 silicone neon light housing designed for 10×10 mm LED channel applications. With an IP67 waterproof rating and 6 mm PCB compatibility, it delivers smooth, flexible illumination for indoor and outdoor lighting designs. Perfect for signage, contour lighting, and architectural decorative use.
Key Highlights in This Video
  • 10 × 10 mm silicone neon light housing for smooth LED diffusion
  • Designed for 6 mm LED PCB strips
  • IP67 waterproof structure for indoor and outdoor use
  • Flexible silicone material for custom shapes and bends
  • 5 m (16.4 ft) roll suitable for longer installations
  • Provides uniform neon-like lighting effects
  • Model: S1010 Neon Light Housing
  • Dimensions: 10 × 10 mm
  • Compatible PCB Width: 6 mm
  • Material: Silicone
  • Waterproof Rating: IP67
  • Length: 16.4 ft (5 m) per roll
  • Use Cases: Signage outlines, architectural accents, decorative contour lighting
Frequently Asked Questions
Q: Is the S1010 housing suitable for outdoor applications?
A: Yes, the IP67 waterproof rating protects it from dust and moisture, making it ideal for outdoor lighting projects.
Q: What LED strip size does this housing support?
A: It is designed for LED strips with a 6 mm PCB width.
Q: Can the housing be bent for curved installations?
A: Yes, the silicone material allows for flexible bending to fit different design shapes.
Q: What is the typical application of this neon housing?
A: It is commonly used for signage, architectural borders, decorative lighting, and ambient glow effects.
Led neon light housing
