850nm IR Rigid LED Strip – 50cm High-Stability Illumination Showcase
Experience the 850nm infrared rigid LED strip in a simple hands-on showcase. See its 36-LED layout, IP65 waterproof build, and stable DC12V performance. Perfect for specialized IR lighting projects requiring compact, durable illumination.
  • Wavelength: 850nm infrared
  • LED Type: SMD2835
  • Length: 50cm rigid bar
  • LED Quantity: 36 LEDs per strip
  • Voltage: DC12V constant-voltage
  • Waterproof Rating: IP65 sealed design
  • Structure: Hard rigid PCB for stability and durability
  • Infrared illumination
  • DIY IR lighting projects
  • Industrial / special equipment
  • Sensor assistance lighting
Key Parameters
LED Qty 36 LEDs
LED Type SMD2835
Length 50cm
Voltage DC12V
Wavelength 850nm
Waterproof IP65
Short FAQ
Q1: Is the strip waterproof?
A1: Yes, it is rated IP65 for moisture and dust protection.
Q2: Does it run on DC12V?
A2: Yes, it requires a stable DC12V power supply.
Q3: Can the strip be used for IR illumination?
A3: Yes, this version uses 850nm infrared LEDs suitable for IR lighting projects.
Q4: How long is the strip?
A4: The rigid bar is 50cm in length with 36 LEDs.
