10mm 4-Pin Transparent Crystal LED Strip L-Connector – Solderless Design
- Transparent crystal housing for a clean installation look
- Solderless design—no tools required
- Compatible with 10mm 4-pin RGB LED strips
- L-connector for precise 90° corner connections
- Secure clip mechanism for stable electrical contact
- Ideal for extending or redirecting RGB strip layouts
- Local stock available in US & UK
- RGB LED strip corner installations
- 90-degree turns in LED strip layouts
- Home decorative lighting
- Display cabinets & signage
- DIY LED lighting projects
Key Parameters
| Compatibility | 10mm 4-pin RGB strips |
| Connector Type | L-connector (solderless) |
| Material | Transparent crystal-style housing |
| Stock Locations | US / UK warehouses |
Short FAQ
Q1: Which LED strips does this connector support?
A1: It is designed for 10mm 4-pin RGB LED strips.
Q2: Does it require soldering?
A2: No, it uses a solderless clip mechanism for easy installation.
Q3: Can this connector handle corners?
A3: Yes, it is an L-connector made for 90-degree angle applications.
Q4: Is local stock available?
A4: Yes, the product is stocked in both US and UK warehouses.
