Transparent Crystal 10mm 3-Pin LED Strip Connector Demo – Solderless Installation
This video demonstrates transparent crystal LED strip connectors designed for quick, solderless connections. The clips support strip-to-strip and strip-to-wire connections while maintaining a clean, low-profile look. Ideal for neat LED strip installations with minimal visual impact.
  • Transparent crystal LED strip connectors for a clean, low-profile look
  • Compatible with 10 mm width LED strips in a 3-pin configuration
  • Solderless clip design for quick and easy installation
  • Supports both strip-to-strip and strip-to-wire connections
  • Clear housing helps keep connections visually discreet
  • Local stock available in the US and UK
  • LED strip lighting installations
  • Projects requiring clean and hidden connections
  • Indoor LED strip setups where appearance matters
Connector Type LED strip connector
Width Compatibility 10 mm
Pin Configuration 3-pin
Installation Method Solderless clip
Connection Types Strip-to-strip, strip-to-wire
Q: Does this connector require soldering?
A: No, it uses a solderless clip design.
Q: What LED strip width is supported?
A: It is designed for 10 mm wide LED strips.
Q: What type of connection does it support?
A: It supports both strip-to-strip and strip-to-wire connections.
Q: Is the connector visible after installation?
A: The transparent crystal housing helps keep the connection visually discreet.
Led strip connectors & cables
