850nm IR Rigid LED Strip – 50cm High-Stability Illumination Showcase
- Wavelength: 850nm infrared
- LED Type: SMD2835
- Length: 50cm rigid bar
- LED Quantity: 36 LEDs per strip
- Voltage: DC12V constant-voltage
- Waterproof Rating: IP65 sealed design
- Structure: Hard rigid PCB for stability and durability
- Infrared illumination
- DIY IR lighting projects
- Industrial / special equipment
- Sensor assistance lighting
Key Parameters
| LED Qty | 36 LEDs |
| LED Type | SMD2835 |
| Length | 50cm |
| Voltage | DC12V |
| Wavelength | 850nm |
| Waterproof | IP65 |
Short FAQ
Q1: Is the strip waterproof?
A1: Yes, it is rated IP65 for moisture and dust protection.
Q2: Does it run on DC12V?
A2: Yes, it requires a stable DC12V power supply.
Q3: Can the strip be used for IR illumination?
A3: Yes, this version uses 850nm infrared LEDs suitable for IR lighting projects.
Q4: How long is the strip?
A4: The rigid bar is 50cm in length with 36 LEDs.
