10mm 4-Pin Transparent Crystal LED Strip L-Connector – Solderless Design
A quick showcase of the transparent 10mm 4-pin LED strip L-connector. Solderless crystal-clear clip design for clean, reliable RGB strip corner connections. Ideal for 10mm RGB LED strip installations, with local stock in the US & UK.
  • Transparent crystal housing for a clean installation look
  • Solderless design—no tools required
  • Compatible with 10mm 4-pin RGB LED strips
  • L-connector for precise 90° corner connections
  • Secure clip mechanism for stable electrical contact
  • Ideal for extending or redirecting RGB strip layouts
  • Local stock available in US & UK
  • RGB LED strip corner installations
  • 90-degree turns in LED strip layouts
  • Home decorative lighting
  • Display cabinets & signage
  • DIY LED lighting projects
Key Parameters
Compatibility 10mm 4-pin RGB strips
Connector Type L-connector (solderless)
Material Transparent crystal-style housing
Stock Locations US / UK warehouses
Short FAQ
Q1: Which LED strips does this connector support?
A1: It is designed for 10mm 4-pin RGB LED strips.
Q2: Does it require soldering?
A2: No, it uses a solderless clip mechanism for easy installation.
Q3: Can this connector handle corners?
A3: Yes, it is an L-connector made for 90-degree angle applications.
Q4: Is local stock available?
A4: Yes, the product is stocked in both US and UK warehouses.
