Installation options and suggestions for Rubik's Cube screens with different numbers of sides
LED Magic Cube Screens, as a visually striking 3D display form, have gained popularity due to their multi-faced design and flexible spatial structure. They are widely used in exhibitions, brand islands, window displays, art installations, stage designs, and more.
Compared to traditional flat screens, Magic Cube Screens capture attention from multiple angles and present more dynamic content in limited spaces.
However, when facing different project needs, many customers often ask: “What size should I choose?” “Should I go for P2.5 or P1.8?” “Should I use a 5-face or 6-face structure?” “How do I ensure the installation is secure and looks great?”
This article will guide you through the selection logic of Magic Cube Screens, focusing on pixel pitch and size, structure face selection, and installation methods, helping you make a more professional and efficient decision for your next project.
1. Selection Logic for Different Pixel Pitch and Screen Size
Magic Cube Screens are commonly used for close-up viewing within a 1–5 meter range, so the focus should be on clarity (pixel pitch) and overall size coordination.
Pixel Pitch
Recommended Viewing Distance
Common Module Size
Suitable Scenes
P1.25
1–2 meters
320×320 mm
Jewelry counters, boutique display booths
P1.5
1–2.5 meters
320×320 mm
Museums, window displays
P1.8
1.5–3 meters
320×320 mm
Brand showcases, tech exhibitions
P2.0
2–4 meters
384×384 mm
Retail spaces, island displays
P2.5
3–5 meters
384×384 mm
Mall atriums, pop-up events
P3.91
≥5 meters
500/512 mm
Stage hanging, outdoor installations
Selection Suggestions:
  • Exhibitions/Window Displays/Museums: P1.25–P1.8, small, high-resolution Magic Cubes
  • Commercial Booths/Island Displays: P2.0–P2.5, balancing cost and performance
  • Stage Performances/Outdoor Decorations: P3.91, large-size, high-brightness, waterproof models
2. Choosing Structure Face Count Based on Environment and Viewing Angle
The “face count” of the Magic Cube directly determines its visibility and visual impact. Different face combinations are suitable for different display needs.
Face Count
Common Structure
Viewing Angle
Application Scenes
1 face
Flat screen
One-way view
Background walls, store windows, wall installations
2 faces
L-shaped screen
Two-way view
Glass window corners, wall corner displays
3 faces
U-shaped screen
Front + two sides
Display counters, exhibition guides
4 faces
Column screen, pillar wrap
Full surround
Mall pillars, airport signage pillars, square islands
5 faces
Open-top cube
Multi-directional
Display tables, interactive islands, exhibition installations
6 faces
Complete cube (Magic Cube)
Fully enclosed
Stage installations, aerial visuals, art installations
Structure Selection Suggestions:
  • For front-only display content: Choose 1–2 face structures
  • For island displays or attracting viewers from multiple angles: Opt for 4 or 5 faces
  • For suspended displays or artistic scenes: Choose a 6-face complete structure
3. Matching Installation Methods with Structure and Design
LED Magic Cube Screens are compact in design but offer multiple installation options. These should be matched with the usage environment, design style, and safety considerations.
Installation Method
Compatible Faces
Typical Scenarios
Installation Key Points
Standing Installation
3–5 faces
Display counters, island booths
Use stands or weighted bases, run cables from the bottom, ideal for flexible setups
Hanging Installation
5–6 faces
Above stage, aerial installations
Calculate weight load on suspension points, factory pre-assembly suggested, stabilize hanging ropes
Wall-mounted Installation
1–2 faces
Background walls, corners
Fixed to the wall, use custom connectors for corners, leave maintenance space
Embedded Installation
1–3 faces
Display walls, showcases
Reserve cutouts for structure and ventilation, coordinate with interior design in advance
Slanted/Custom Installation
Any faces
Art scenes, interactive guides
Custom brackets, pre-set angles by the factory, ensure center of gravity and safety
Installation Suggestions:
  • For repeated use: Recommend standing installations with detachable stands
  • For art/stage setups: Prefer hanging installations with hidden wiring
  • For rotating/custom shapes: Pre-assemble and transport as a whole in the factory to ensure consistency
🎯 Recommended Magic Cube Products for Different Scenarios
🎯 High-end Display Spaces: Choose the High-Resolution Indoor P1.8 Magic Cube
When you need close-up viewing and ultra-precise visuals, the Indoor P1.8 is the ideal choice:
  • Museum exhibitions, art displays
  • Jewelry, watches, high-end retail showcases
  • Tech brand exhibition zones, premium pop-up stores
💡 Recommended Products:
  • Indoor P1.8 320×320 mm 5-Face Cube – GOB encapsulation protection, ultra-high resolution, ideal for refined display booths
  • Indoor P1.8 Stackable Modules – Multiple units for immersive 3D info displays
🏬 Storefronts and Exhibition Booths: Balanced P2.5 Indoor Magic Cube
The P2.5 indoor model balances clarity and brightness, suitable for most indoor commercial displays:
  • Mall island counters and retail showcases
  • Exhibition halls and interactive zones
  • Brand display columns in retail spaces
🌦 Outdoor Ads and Installations: Waterproof P2.5 Outdoor Magic Cube
Designed for outdoor use with IP65 protection, ensuring all-weather operation:
  • Storefront advertising light boxes
  • Outdoor plaza or street art installations
  • Stadium signage columns or temporary event setups
🏗 High-Hanging and Far-View Setups: Lightweight, High-Brightness P3.91 Magic Cube
For high-altitude installations or long-distance viewing needs, the P3.91 offers the best combination of brightness and lightweight design:
  • Mall atrium hanging displays
  • Stage art installations and interactive light sculptures
  • High-position directional signage in corporate lobbies
🎨 Customizable Magic Cube LED Displays: Create Your Unique Display Effect
Custom Magic Cube LED Display – Design your own LED cube, supporting any size, pixel pitch, and number of faces, fully customized to your needs. If you require different styles or specific display features, we offer complete customization services to help you achieve a unique visual experience.
🧾 Conclusion
The selection process for Magic Cube Screens is a comprehensive decision-making process that covers pixel pitch, size, and installation methods. Choosing wisely ensures not only installation safety and easy future maintenance but also enhances the visual impact and branding effectiveness of your display content.
We recommend working closely with your screen supplier or system integrator early in the project to clarify your installation space, viewing distance, and display content requirements. This way, you can quickly develop a more scene-matching, high-performance, and cost-effective solution.
If you have any further questions about selecting Magic Cube Screens, feel free to reach out to us anytime. We’re here to offer professional advice and custom support.
Magic cubic led display
